Butch 194 #1 Posted October 22, 2011 Can my C-175 handle that much wattage or will something blow. I have a headlight that is out and would like to replace them both with something brighter. Thanks. Share this post Link to post Share on other sites
Raider12 14 #2 Posted October 22, 2011 I think you will be fine! I used to run a pair of automotive fog lamps as headlamps on my Raider 12 with a k-301 and never had an issue. Share this post Link to post Share on other sites
Kelly 1,038 #3 Posted October 22, 2011 My 520's have halogen bulbs factory, they are brighter than the 312 I had, maybe just find a set of them, I'm sure a auto parts store can set you up, just make sure the connectors on the bulb will work with your wiring or you may have to replace the ends. Share this post Link to post Share on other sites
HorseFixer 2,015 #4 Posted October 22, 2011 GO the Leds and quit goofing around with those DINASOUR Bulbs :dunno: Share this post Link to post Share on other sites
KC9KAS 4,746 #5 Posted October 23, 2011 According to OHM's Law, the 2 lights @ 60 watts each will pull 10 amps from your system. If you have additional lights or equipment drawing current, you need to factor that current draw also. Your charging system is probably 15 amp....correct? Share this post Link to post Share on other sites
Butch 194 #6 Posted October 23, 2011 According to OHM's Law, the 2 lights @ 60 watts each will pull 10 amps from your system. If you have additional lights or equipment drawing current, you need to factor that current draw also. Your charging system is probably 15 amp....correct? Heck I don't know! :dunno: Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #7 Posted October 23, 2011 This is a pretty decent deal: Halco 107798 Share this post Link to post Share on other sites
