rydogg 186 #1 Posted October 7, 2011 I got my other D200 running and took it out for a drive and the hydro is good and strong I found the steepest ditch to drive it up and it went up with no problem I even stopped in the middle gave her the beans and she took right off I thought I was going over backwards I ran the tractor for about an hour to make sure she got good and warmed up and the hydrostatic transmission worked flawlessly and the motor runs like a watch no smoke or sputter just a nice smooth running twin but I am unable to get the hydraulic mid and rear lift to work anyone know where I should start troubleshooting the model number is 1 0631 Share this post Link to post Share on other sites
Nathan Werneburg 0 #2 Posted October 9, 2011 well i would set up a guage on the inlet to the cylender and a guage at the inlet to the valve set up and make sure u have pressure at these two point when u have the lever enguaged and if u do then u have a bad return and if not then u know where to start also did u check the tranny fluid level if its low it wont have enough fluid to move this thing lol Share this post Link to post Share on other sites
