coldone 35 #1 Posted September 26, 2011 Ok so we have the intake and carb working good. Decarbed the head and did a vlave job. Reset the valves to spec. Now I am blowing oil up into the air cleaner via the breather tube. I am blowing so much that the oil is running down the venturi and into the intake. When I get a enough or mow on the hill it looks like I am fogging for skeeters. I ran a compresion test a few days ago and I am getting between 110psi and 115psi on both cylinders. The engine does smoke a little at start up and then a little before it starts slugging into the breather tube. The engine is a BF/MS on a wheel horse D160. This model uses a breather tube without the mesh inside it like the BM models. I just ordered a new tube from onanparts.com because my old one was cracked into. Share this post Link to post Share on other sites
