zieg72 209 #1 Posted September 18, 2011 Looking for suggestions on a smaller steering wheel for my 520H. I have tried a wheel off a C165 but the way the pin goes through makes the wheel 45 degrees off. Do they make a 3 spoke in the same size that would fit with the pin horizontal when straight. Looking for suggestions. Share this post Link to post Share on other sites
rmaynard 17,642 #2 Posted September 18, 2011 Can't you lift the steering shaft and rotate it 45 degrees? Share this post Link to post Share on other sites
Kelly 1,038 #3 Posted September 19, 2011 You have to get to the collar behind the dash, loosen the set screw move the collar down the shaft till you can pull the upper steering shaft up, till you can turn it, then slip it in where you want it, put everything back and your set. Share this post Link to post Share on other sites
zieg72 209 #4 Posted September 19, 2011 You have to get to the collar behind the dash, loosen the set screw move the collar down the shaft till you can pull the upper steering shaft up, till you can turn it, then slip it in where you want it, put everything back and your set. Thanks, I'll give it a try Share this post Link to post Share on other sites
