Stigian 1,234 #1 Posted September 16, 2011 Howdo chap's, my Raider 10 (now 12) lost it's original cutting deck way back in the mists of time, and has been running a deck from (I think) a 518. Trouble is the deck drive belt (no idea where it came from) is now totally stretched beyond use. I know the standard Raider belt is too short to fit, so should I be looking for a 518 deck belt? And what size are they? Any help with this would be great, My Wife is moaning that the lawn needs cutting :banghead: Share this post Link to post Share on other sites
rmaynard 16,293 #2 Posted September 16, 2011 Do you have a model number for the deck? Share this post Link to post Share on other sites
tarcoleo 119 #3 Posted September 16, 2011 Ian- Hi. Hard to know how your tractor will align with this deck. You will need a 1/2" belt ("A" belt). Find a length of 1/2" rope and run it around the PTO, mule drive and deck sheave and measure the exact length to complete the circuit. This will provide a reasonable approximation of an after-market kevlar belt that can do the job. If you get a belt within an inch of ideal, there likely is enough adjustment in the mule drive to make it work, or you can take the belt back to the supplier and get one a size larger or smaller. Good luck. Tom in RI (part of New England) :thumbs2: Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted September 16, 2011 Since your Raider has a front Attach-Matic hitch it should be easy to get the correct belt. When used with a "typical" long-frame tractor, a 42 or 48 inch SD deck will take a 103" long belt. A 42" RD deck needs a 98" belt, and the 36" 3 blade (RD or SD) decks take a 97" belt. I ran a 42" SD deck on my 1966 1056 and used the belt from the 1984 GT WorkHorse the deck came off of. Share this post Link to post Share on other sites
Stigian 1,234 #5 Posted September 20, 2011 Hi Guy's thanks for the help, between you reply's I managed to work out which belt I need and have just ordered it. Guy's. A bit late now but here is the cutting deck model number for you Bob.. E542MS01 10176. Share this post Link to post Share on other sites
rmaynard 16,293 #6 Posted September 20, 2011 A bit late now but here is the cutting deck model number for you Bob.. E542MS01 E5-42MS01, 42" Side Discharge Mower, 1988 As TT stated previously, the 42" SD uses a 1/2" x 103" belt. The Toro part number is 102742. Share this post Link to post Share on other sites
