fourwheels0 191 #1 Posted August 22, 2011 ok i just changed the oil on my 14 hp magnum (in a 1988 414-8 speed) and the level on the dipstick is about 1/4 inch below the low mark. i put 2 quarts in as that is what i read it is supposed to take. as far as i know the dip stick is original. why would it be that low?. would this engine take 2 1/4 quarts like the 16hp magnum?. p.s the end of the dipstick has a bend in it. is that normal? Share this post Link to post Share on other sites
CRE1992 143 #2 Posted August 22, 2011 Mine has approx a 45 degree angle on the dip stock to get it into the oil pan. I put 2 quarts in and then just filled it until it reached the mark on top. Share this post Link to post Share on other sites
fourwheels0 191 #3 Posted August 22, 2011 yup mine has about a 45 degree bend in the tip too. ok so i think that's good. i'll top off the oil till it hits the full mark. thanks. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,110 #4 Posted August 22, 2011 The 1988 414-8 oil capacity is 2-1/2 quarts in the operator manual and the Wheel Horse lubrication charts. Garry Share this post Link to post Share on other sites
fourwheels0 191 #5 Posted August 22, 2011 garry your right. i topped it off till the full mark and it was 2 1/2 quarts exactly. thanks. the kohler site said 2 quarts for the 14 hp magnum. i guess it's a misprint. Share this post Link to post Share on other sites
Duff 206 #6 Posted August 24, 2011 Just a thought here - the single cylinder Magnums are splash lubed. I have a couple of hills on my property that I have to go up and down - not terribly steep, but steep enough. I run all three of my Magnums (two 12's and a 10) about 1/4-3/8" over the full mark to give the reservoir a little more room. I don't seem to have any problems with blowing oil out anywhere, and it gives me a little peace of mind. JMHO.... Duff :thumbs2: Share this post Link to post Share on other sites
