skinne44 0 #1 Posted August 15, 2011 Currently have my 1974 D 180 torne down for a freshen up and noticed one of the rear axle seals is leaking. How hard are these seals to replace and where can I get them? Thanks. Share this post Link to post Share on other sites
TT-(Moderator) 1,129 #3 Posted August 16, 2011 There are countless threads here on seal removal. The "search" function is a joke on these forums, but I'm sure you'll find a few if you just look back through the "transmissions and transaxles" sub-forum. You'll basically need to apply the same technique(s) used to remove many other lip-type seals. Seals are still available from the OEM (Toro) or they can be "crossed" to various aftermarket supplier numbers. (CR / SKF / National, etc.) Share this post Link to post Share on other sites
