P3x
Probably a Stupid Question...
P3x
Probably a stupid question but I'd rather be humbled than scratch my 520! What holds the instruments into the panel? After the closeout layer is removed the instruments seem mounted and secured to the sheet meyal panel with a plastic ring.
Tried turning ever so gently :woohoo: and they do not seem threaded. Before I attempt to really go Buuba on it, I figured I ask some who knows.
Thank You.
P3x
CRE1992
Look behind the battery, there will be machine screws that are fused with the plastic in the gauges along with a metal brace with little nuts holding it in place. The Gauge itself has a lip which holds it from falling through the holes in the dash.
