tmix 34 #1 Posted July 21, 2011 Here are some pics Of things that I have made had to mount them to see if they worked The handle is a New twist to Wheel Horse Handle I did not want to lean way over for the handle. So I am trying a part from a pedal bike Because its not a straight shot like the Wheel horse lever So here comes the brake cable. Seems to work good in the garage .Grab goods on he Axle came out pretty good . Had to make lifting rod for some reason the old tab on plow bracket was to for forward so when you put up a straight rod it hit the steering shaft so welded a new tab on .Now WORKS like DREAM . T MIX IMG] G] [i[/img [ [/img Share this post Link to post Share on other sites
KyBlue 652 #2 Posted July 21, 2011 Good idea on the brake Handle/Cable. Not to be a but if you modify those Axle brackets to work like the OE brackets, It'll move the Plow back to the proper place for the lift link to connect to. I Got my set off Flea-Bay, and didn't know they were wrong until I tried to mount up the tiller ... This is how they should be, with the notch directly under the Axle.. Share this post Link to post Share on other sites
tmix 34 #3 Posted July 22, 2011 OOPS --- I couldn't figured out what was going on I had to Add one more Tab on the Plow FRAME!!! Works like a DREAM NOW NO more bening over for the angle Handle !!! Painting parts today pictures hope up sometime soon !!!! T MIX Share this post Link to post Share on other sites
smoreau 658 #4 Posted July 22, 2011 Good idea on the brake Handle/Cable. Not to be a but if you modify those Axle brackets to work like the OE brackets, It'll move the Plow back to the proper place for the lift link to connect to. I Got my set off Flea-Bay, and didn't know they were wrong until I tried to mount up the tiller ... This is how they should be, with the notch directly under the Axle.. If that's your 875 tractor your brackets are right for a short frame plow tmax. The short frame plow takes a different plow then the c series. Share this post Link to post Share on other sites
tmix 34 #5 Posted July 22, 2011 Hey SMOREAU-- I copied the 875 Brackets Because thats the Best I could do.Ya And I didn't know any better U.P Pride Buddy!!!! T Mix :woohoo: Share this post Link to post Share on other sites
