fourwheels0 191 #1 Posted July 15, 2011 1989 416-8 with an onan won't charge. what can be wrong and how much to fix. regulator? stator? Share this post Link to post Share on other sites
SAM58 30 #2 Posted July 15, 2011 Won't charge at all or not much? I had a 1985 416-8 and the charging system was based on engine RPM's (Seperate curcuit) Lights would get dim @ low RPM's... also the gauge was a amp Gauge instead of voltage. Mine looked like it was not charging much unless i had it running at max RPM's Although mine had a Kohler engine as well... Share this post Link to post Share on other sites
Save Old Iron 1,568 #3 Posted July 15, 2011 at full engine RPM's stator AC VOLTS should be greater than 30 VAC the output of the voltage rectifier regulator should be at or above 13 ish DC volts. Approximately 14.5 volts DC from the rectifier is considered optimal. Anything above 13.5 will charge the battery - albeit at a slower rate. check all the connections from stator to rectifier unit - these are usually corroded on older tractors. Share this post Link to post Share on other sites
can whlvr 994 #4 Posted July 16, 2011 when my kohler would not charge it was the ground for the rectifier,i ran a separate wire from the bolts of the rectifier to a good ground and that fixed it Share this post Link to post Share on other sites
fourwheels0 191 #5 Posted July 16, 2011 thanks guys. i'm going to go look at the tractor tomorrow and see how bad it is and hopefully buy it if i can get it at the right price. Share this post Link to post Share on other sites
