71_Bronco 1,072 #1 Posted July 11, 2011 I picked up a 42" Side discharge deck over the weekend for my Bronco 14. I want to pick up a spare set of blades for it, just in case anything happens. How do I find the right blades for my deck? Do I just have to find ones that say "for 42 inch deck"? Or do they vary depending on what year deck I have? Any help would be greatly apprecieted. Thanks Share this post Link to post Share on other sites
SAM58 30 #2 Posted July 11, 2011 check out this ... Hopfully you can see the Model tag on the deck? Go to the Toro Site and fine a parts list... Toro Manuals & Parts Just type in the WheelHorse part number at the link below and they should have it at a good price. RCPW Share this post Link to post Share on other sites
71_Bronco 1,072 #3 Posted July 12, 2011 I tired looking on the deck for any type of model or serial number, and found none. the only decals left are showing the routing of the pulleys, and the warning labels, nothing about deck identification. Is my next bet to take off a blade, measure it up, and post on here to see if somebody has the same blade and possibly a part number? Thanks Share this post Link to post Share on other sites
WH nut 553 #4 Posted July 14, 2011 If the tag is still there is should be on the left side bolted into the wheel bracket Share this post Link to post Share on other sites
71_Bronco 1,072 #5 Posted July 14, 2011 If the tag is still there is should be on the left side bolted into the wheel bracket I didnt see anything like you described. I did see a label / decal on the left side (non-chute side), but it was too worn and banged up to read anything on it. Share this post Link to post Share on other sites
jdog_kustoms 82 #6 Posted July 14, 2011 you need part number 10636 it is a set of 3 blades for the 3/4 inch shaft deck in 42 inch and you can also get blades at your local napa dealer Share this post Link to post Share on other sites
71_Bronco 1,072 #7 Posted July 14, 2011 Thanks J-Dog. I am one of those people who like to have spares around just in case. Thanks for the info! Share this post Link to post Share on other sites
