mack1605 8 #1 Posted June 5, 2008 what are the measurements of a c-160 automatic drive belt Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #2 Posted June 5, 2008 P/N 7478 is a 5/8" wide X 84" long belt, Mark. Share this post Link to post Share on other sites
mack1605 8 #3 Posted June 5, 2008 thank you tt i knew you would know thanks mark Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #4 Posted June 5, 2008 That is still a good number if you want to get it from your dealer. (a little over $20 - but worth it when it comes to fit & quality. ) How are you making out with that lift control valve? :whistle: Share this post Link to post Share on other sites
mack1605 8 #5 Posted June 5, 2008 the breakdown of the lift valve was what i needed fixed that and now on to next issue were gaining on it thanks again tt Share this post Link to post Share on other sites
mack1605 8 #6 Posted June 5, 2008 yes i put new drive belt on still doesnt wanna go up hill to good and if mower is running forget it i changed oil and filter any one have any ideas Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #7 Posted June 6, 2008 You can thank Jason Schahl for the control valve diagram. Is it running out of engine power, or just not "pulling" the tractor, Mark? If it just feels like it's slipping, check the tow release valve. I'm not sure exactly where you'll find it on your 160, but it's there on the pump block somewhere. (maybe you already checked it?) Look for the obvious sheared axle keys, etc. first, and we'll hope it's not an internal issue with the hydro unit. Share this post Link to post Share on other sites
mack1605 8 #8 Posted June 6, 2008 ok tt thanks to j schahl for to lift valve break down . tt no the motor doesnt slow just doesnt pull ive says to turn valve one turn left to tow one turn back to drive the screw is burried to the right cant go any further and i will ck the keys in rear wheels thanks tt Share this post Link to post Share on other sites
CasualObserver 3,416 #9 Posted June 6, 2008 You're welcome Mark... wish I had some advice for you on your issues... but I know virtually nothing about hydraulics. Good luck! Share this post Link to post Share on other sites
mack1605 8 #10 Posted June 6, 2008 ok thanks jschal maybe someone on here can help me or tt can redirect this some where will they will know Share this post Link to post Share on other sites
