Curt 0 #1 Posted July 5, 2011 A friend gave me a Wheel Horse LT1642. Need info on how to tighten belt from engine to mower deck, belt is loose when engaged, I don't see a tensioner pulley or any adjustment. Any help would be appreciated. Thanks Curt Share this post Link to post Share on other sites
chazm 413 #2 Posted July 5, 2011 Hello & Not to familiar with that trator ,but someone will be along to help you out. Good luck with her Chaz :D Share this post Link to post Share on other sites
SNYFIX 13 #3 Posted July 5, 2011 A friend gave me a Wheel Horse LT1642. Need info on how to tighten belt from engine to mower deck, belt is loose when engaged, I don't see a tensioner pulley or any adjustment. Any help would be appreciated. Thanks Curt On the bracket up front where you slide the ""J"" hook after sliding it into the rear bracket should be just a simple 2 1/2 inch (or so) threaded bolt w/locknut. Tightening the bolt moved the deck back tightening the belt. Set the lock nut after tightening and your ready to mow !!! Share this post Link to post Share on other sites
Curt 0 #4 Posted July 5, 2011 A friend gave me a Wheel Horse LT1642. Need info on how to tighten belt from engine to mower deck, belt is loose when engaged, I don't see a tensioner pulley or any adjustment. Any help would be appreciated. Thanks Curt On the bracket up front where you slide the ""J"" hook after sliding it into the rear bracket should be just a simple 2 1/2 inch (or so) threaded bolt w/locknut. Tightening the bolt moved the deck back tightening the belt. Set the lock nut after tightening and your ready to mow !!! Thanks, found the bolt,tightened it, all is well....Curt :woohoo: Share this post Link to post Share on other sites
rmaynard 17,642 #5 Posted July 5, 2011 :woohoo: Glad you found your answer. Share this post Link to post Share on other sites
