lotus 0 #1 Posted June 30, 2011 Because of ignition problems with my red steed, I improvised the wire conections to the ignition, and it worked, i got my horse started and mowed the lawn. At the end my Wheel Horse died, like completely, it seems that in my futile attempts to fix the ignition, i have managed to keep the DC starter motor running all the time it took to mowe the lawn. So im standing here trying to figure out what part failed, from a quick DC motor test, i think that at least its okay. But what else could have failed and killed my horse? Share this post Link to post Share on other sites
smoreau 658 #2 Posted June 30, 2011 :woohoo: and it would help if you told us what model tractor you have we can help you figure out whats wrong with your tractor. Share this post Link to post Share on other sites
lotus 0 #3 Posted June 30, 2011 helloooo Its a Wheel Horse 108. Share this post Link to post Share on other sites
HorseFixer 2,015 #4 Posted June 30, 2011 :D On yer tractor... Uhh no such thing as a model 108 Cheers ~Duke :ROTF: Share this post Link to post Share on other sites
lotus 0 #5 Posted June 30, 2011 A model 108 it is If in doubt google Wheel Horse 108. I must warn you, its kinda old. But I think we can get along even if you dont know my model. The electrical components must be (relatively) the same, on this kind of lawn mowers...the ones you sit on. I would like to know what parts usually could be responsible for why the DC starter motor wont get any current? Stator? regulator? etc. And how to test if they are broken. Share this post Link to post Share on other sites
rmaynard 17,642 #6 Posted June 30, 2011 Yup, a rear engine rider. Let me take a look in the files, I may have a manual. At least that's a starting point. :woohoo: Share this post Link to post Share on other sites
VinsRJ 724 #7 Posted July 1, 2011 :D And good luck with the fix, lots of good people here willing to help. :woohoo: Share this post Link to post Share on other sites
rmaynard 17,642 #8 Posted July 1, 2011 Take a look and see if you can find the ID tag. Should be one of the following numbers: 33-08B301 33-08B303 23-08B304 33-08B401 33-08B402 33-08B501 33-08B502 33-08B503 33-08B504 33-08X301 33-08X303 B3-08B302 B3-08B303 B3-08B391 Share this post Link to post Share on other sites
rmaynard 17,642 #9 Posted July 1, 2011 I searched Toro Master parts viewer and came up with all those numbers listed above. However, having checked my manuals, the closest thing I have is a 110-4 owners manual. Share this post Link to post Share on other sites
Duff 207 #10 Posted July 1, 2011 Duke-ster, I have to disagree with you, buddy - 108 was indeed a model number. Back in the '90's I had a 108R, 8 hp. vertical engine (can't remember who made the motor)and it was a for sure. Rear engine rider, built better than anything comparable I've seen before or since in the rear-engine rider department. Duff :woohoo: Share this post Link to post Share on other sites
M151A1 2 #11 Posted July 1, 2011 I just did a search on Google Images for "108 Wheel Horse rear engine" and came across a Toro Wheel horse 108-3 for sale. It is a 8hp B&S rear engine rider, with bagger, 30" deck 3-speed for $299 There is a picture with the model number visiable that reads 108-3. http://www.husqvarna.com/us/homeowner/deal.../used-products/ Hope this helps. Tyson Share this post Link to post Share on other sites
HorseFixer 2,015 #12 Posted July 1, 2011 Duke-ster, I have to disagree with you, buddy - 108 was indeed a model number. Back in the '90's I had a 108R, 8 hp. vertical engine (can't remember who made the motor)and it was a for sure. Rear engine rider, built better than anything comparable I've seen before or since in the rear-engine rider department. Duff Well allrighty then 108 it is..... Now let's have a Cheers ~Duke :D Share this post Link to post Share on other sites
MikesRJ 563 #13 Posted July 1, 2011 There were, in fact, 14 models in the 108 Rear Engine Rider line, built between 1981 and 1988. Maynard had it right all along, and the other bob was talking out his backside. Go figure? B3-08B302 1981 108-3 Rear Engine Rider 33-08B301 1985 108-3 Rear Engine Rider 33-08B501 1985 108-5 Rear Engine Rider 33-08X301 1985 108-R Rear Engine Rider 33-08B303 1986 108-3 Rear Engine Rider 33-08B502 1986 108-5 Rear Engine Rider 33-08X303 1986 108-R Rear Engine Rider B3-08B303 1986 108-3 Rear Engine Rider 33-08B304 1987 108-3 Rear Engine Rider 33-08B401 1987 108-4 Rear Engine Rider 33-08B503 1987 108-5 Rear Engine Rider B3-08B391 1987 108-3 Rear Engine Rider 33-08B402 1988 108-4 Rear Engine Rider 33-08B504 1988 108-5 Rear Engine Rider Share this post Link to post Share on other sites
lotus 0 #14 Posted July 1, 2011 Now that we have established that my Wheel horse really do exist, i hope that we are ready to move on and face the real problems As I stated earlier, the DC motor works, so something that is supposed to supply the DC motor with power obviously does not work. So my red horse team mates, fire away what could be the cause! :woohoo: Share this post Link to post Share on other sites
rmaynard 17,642 #15 Posted July 1, 2011 Hang in there Lotus, if someone can locate a wiring diagram it would be a lot easier. The 108 series is not as collectible as the tractors, therefore little is know by most of us. Hopefully someone will come along with the answer you need. Share this post Link to post Share on other sites
WH nut 553 #16 Posted July 1, 2011 Now that we have established that my Wheel horse really do exist, i hope that we are ready to move on and face the real problems As I stated earlier, the DC motor works, so something that is supposed to supply the DC motor with power obviously does not work. So my red horse team mates, fire away what could be the cause! Battery maybe? :D Share this post Link to post Share on other sites
bigd 0 #17 Posted July 1, 2011 it sounds like you managed to run a hot wire to energize the solenoid or your solenoid is stuck. Share this post Link to post Share on other sites
HorseFixer 2,015 #18 Posted July 1, 2011 There were, in fact, 14 models in the 108 Rear Engine Rider line, built between 1981 and 1988. Maynard had it right all along, and the other bob was talking out his backside. Go figure? Share this post Link to post Share on other sites
lotus 0 #19 Posted July 1, 2011 If I bypass the ignition system and connect my car battery to the DC starter motor, which in turn would make the main motor turn(i dont know its technical term for that motor) Would it be enough to power the spark plug? through the ignition coil or magneto circuit ofcourse. Or is it likely that the spark plug circuit cant be bypassed around the ignition circuit? Share this post Link to post Share on other sites
farmer 1,081 #20 Posted July 1, 2011 Forget the Bat Signal, RS needs a Squirrel signal :woohoo: Share this post Link to post Share on other sites
HorseFixer 2,015 #21 Posted July 1, 2011 If I bypass the ignition system and connect my car battery to the DC starter motor, which in turn would make the main motor turn(i dont know its technical term for that motor) Would it be enough to power the spark plug? through the ignition coil or magneto circuit ofcourse. Or is it likely that the spark plug circuit cant be bypassed around the ignition circuit? Lotus can you help us out, and can you find your Model # it will help us determine what model and year you have. We know what the Product name or type of tractor you have but it may help, as I possibly can call My Toro Dealer and have him Fax Me a wireing diagram for your specific Tractor. There are many different Models withing the 108 catergory. My dealer is going to ask me for that model # information when I call him. Lotus, yes you can turn over the tractor that way with car battery by having the ground to the engine and touch hot lead to your starter. (use long leads as to keep sparks away from yer battery) But you will also need to energize the coil in order to get spark (that is if you have a coil type setup). I would rather see you start that engine through a solenoid the correct & safe way. Cheers ~Duke :P Share this post Link to post Share on other sites
MikesRJ 563 #22 Posted July 1, 2011 flap, flap, flap ... Somebody out there has to have a Wiring Diagram for one of these. Let me check the archives and I'll see what I can locate. Share this post Link to post Share on other sites
rmaynard 17,642 #23 Posted July 1, 2011 The 108's had an 8HP Briggs & Stratton engine. According to Toro, there were two different engines. A 109707-2154-01 and a 193707-0148-01. The latter is the only one that comes up at the B&S web site. You can go to the Briggs & Stratton web site and download a parts manual, and an owners manual. I looked at them, but they did not offer too much help for your situation. Maybe you can contact B&S and see if they have a wiring diagram for the engine. From what I did glean from the parts pictures, there are several different stators. So you are working with an alternator type engine. That means that somewhere on the engine or the tractor is a rectifier to convert the AC to DC for charging the battery, Share this post Link to post Share on other sites
lotus 0 #24 Posted July 1, 2011 My Horse id numbers are more or less worn off, but i have the demystification guide and i have found some schematics in it, now i just have to understand what it. :woohoo: Share this post Link to post Share on other sites
HorseFixer 2,015 #25 Posted July 1, 2011 My Horse id numbers are more or less worn off, but i have the demystification guide and i have found some schematics in it, now i just have to understand what it. Awe crap, figured thats why ya never posted the model in the first place! Do you have a scanner to scan the schematics. I have a rear engine 1982 WH Rider RR832 type Model # A3-083201 does have a briggs I think I have the manual I can ck and scan & post if schematics are in there if ya cant scan & post yers. Lemme know. Cheers ~Duke :D Share this post Link to post Share on other sites
