idruthrbfishin
Farm Land Lease
idruthrbfishin
I was wondering if anyone knew the average rate per acre to lease farm land. I am considering buying a 100 acre farm of which approx. 70 acres are tillable. I would like to see the land farmed, but do not have the resources to farm it myself. If I could lease the land to a local farmer, the lease pmt. would help out with the taxes.
Gene_S
I have some farm land and I get $150 per acre. Sure makes a nice check in the spring and the fall. More then pays for the taxes and helps buy some :hide: stuff...
bigd
depends on where you are.around defiance ohio it goes for 60.00 around decatur ind 150 depends ask at you local feed mill maybe the county extension office
puddlejumper
Dont, forget to figure lay of the ground and if its been tiled or not. I realize you ask for a average but the lay of the ground and the way its been maintained or raped makes a differance.
