ricksrj58 273 #1 Posted June 20, 2011 ok before i pop the forks out, can the gear on the bottom of the cluster be flipped over since the teeth on top are worn away? Share this post Link to post Share on other sites
racinfool40 203 #2 Posted June 20, 2011 That's your input shaft it is suppose to be like that. The Gear right above it on the shift fork should slide right over the top of the input gear and mesch together...I'd finish pulling it all apart and check things from there, After a good cleaning.. :hide: Share this post Link to post Share on other sites
ricksrj58 273 #3 Posted June 20, 2011 answered my own question when it fell apart lol thanks Share this post Link to post Share on other sites
ricksrj58 273 #4 Posted June 20, 2011 just bought all new bearings and seals but bdi bearing cannot find a replacement bearing for the the axle.bearing has what looks to be #7439 on it.can i still get this from toro dealer? Share this post Link to post Share on other sites
racinfool40 203 #5 Posted June 20, 2011 # 7439 is the 1533 ball bearing and the only place to get them is Toro about 80.00 a piece Their has been many a person look for a cheaper alternative and still to this day No luck!!! Share this post Link to post Share on other sites
ricksrj58 273 #6 Posted June 20, 2011 ok thanks for the info,i called the dealer and ordered 2.i want to have this tractor together for this weekend and should have all bearings and seals by wed. Share this post Link to post Share on other sites
stevasaurus 23,661 #7 Posted June 20, 2011 You have some cleaning to do. If you do not have gunk tank...mineral spirits works great...use some bearing grease in the bearings after they are cleaned...not too much...just enough to keep the needle bearings in place when you put it back together. Let us know. :hide: Share this post Link to post Share on other sites
ricksrj58 273 #8 Posted June 21, 2011 got everything cleaned up and now just waiting for all my bearings to come in.i am hoping to have this 857 together for the show. Share this post Link to post Share on other sites
