dmoore 1,042 #1 Posted June 9, 2011 I am having trouble leveling my 1979 42" side discharge mower deck as per the owners manual...the trunnion at the rear doesn't seem to be doing anything...I have adjusted the trunnion on the lift arm to where the bumpers just touch the underside of the foot rest...but that's all I can accomplish...the deck needs to come up at the rear...when a small 2ft level is placed on the deck front to rear the bubble is completely out of the lines...even at the highest setting it still cuts too low...any one have this problem? Thanks! Dave :hide: Share this post Link to post Share on other sites
corn53 4 #2 Posted June 9, 2011 I have just worked on one. Are ur rear wheels even?? Take the deck off to check it throughly as it was hard for me to see it on mine. Mine had a dent on the right side where the bracket was. I had 2 undo the whole rear wheel assembly and bang the deck straight again. Then I had to readjust the mounting clip also. PO must have a good rock with it!!! Used it for the 1st time 2day and it worked great. Hope this helps. :hide: Share this post Link to post Share on other sites
dmoore 1,042 #3 Posted June 9, 2011 Clear has mud .....My deck is not that old(replaced the shell 10 years ago)I have to be missing something just not sure what that is :) Share this post Link to post Share on other sites
Clarkbug 0 #4 Posted June 9, 2011 Are your deck wheels the right size? The PO of my deck had replaced the originals with some that were much smaller than the OEM ones. Share this post Link to post Share on other sites
Trouty56 568 #5 Posted June 9, 2011 I use the highest setting and the bumpers are very close. The deck raises only a little bit when lifted. But my deck is level though. Best get some pictures for these guys to examine. Share this post Link to post Share on other sites
can whlvr 994 #6 Posted June 11, 2011 these wheelhorse decks seem to be a close cut even when on highest setting,bush hogging is a little diffacult even with the deck raised,yes it can be done but slowly Share this post Link to post Share on other sites
dmoore 1,042 #7 Posted June 14, 2011 Ok, I removed the rear threaded leveling rod & now it is level and slightly raised back to front just like the owners manual sez it should be......it cuts great but seems a lil low for the highest setting at the quadrant....Are you supposed to use the dial-a-height to adjust the deck height? D Share this post Link to post Share on other sites
dmoore 1,042 #8 Posted June 16, 2011 Anyone? :hide: Share this post Link to post Share on other sites
oldredrider 2,554 #9 Posted June 16, 2011 Low cutting heights seem to be one of the common complaints of the WH decks. Someone here recently suggested using deck wheels 1" larger to give a higher cut. Although I haven't tried it, it makes sense this would give the needed "lift" to give a higher cut. Using the height adjuster to increase cutting height would negate the "free float" needed to get an even cut. Hope this helps. Let us know Share this post Link to post Share on other sites
dmoore 1,042 #10 Posted June 17, 2011 Thanks for the input Paul.....yes I guess that would defeat the free floating design of the deck......I am re-installing the leveling rod tomorrow & looking at the situation a lil harder....maybe larger wheels are the easy fix......D Share this post Link to post Share on other sites
skrusins 128 #11 Posted June 17, 2011 Some discussions about this on the link "Deck height too low" It's just below yours. Dial a height is to be used for a blade or tiller not a mower hope this helps Share this post Link to post Share on other sites
