fi57 0 #1 Posted June 2, 2011 My 518xi has a problem with the oil temp & fuel gauges. The oil temp gauge red lines after short time. Changed sending unit & checked all air inlets for deris, oil level is OK . Oil temp gauge still red lines. Could it be a bad gauge? Also fuel gauge reads full all the time. Can anyone help? Thanks NICK Share this post Link to post Share on other sites
jdog_kustoms 82 #2 Posted June 2, 2011 I am having the exact same problem with my Toro made new Holland gt 18 so keep me informed on what you find out I have already pulled all tins off motor to make sure it was all clean rebuild carb checked for intake to heads and carb to intake gasket leak found none And I don Share this post Link to post Share on other sites
knever3 0 #3 Posted June 4, 2011 It sounds like you have a bad ground. With two gauges going awry your gas gauge needs a reference ground to complete the circuit since it is just a resistor. Check all the grounds in the engine compartment since the hood sides are removable that's the easy part. Share this post Link to post Share on other sites
