fourwheels0 191 #1 Posted June 1, 2011 will my snowplow/dirtblade for my c-81 fit on a charger 12?. my c-81 has the quick attach system. Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted June 1, 2011 Yes direct fit, you will need to swap the axle bracket. Share this post Link to post Share on other sites
fourwheels0 191 #3 Posted June 1, 2011 ok thanks. that's good to know. Share this post Link to post Share on other sites
fourwheels0 191 #4 Posted June 1, 2011 well i got it but it's a electro charger 12. is there any difference? plow will still mount up correct? Share this post Link to post Share on other sites
Cody 285 #5 Posted June 1, 2011 Yup the plow will mount up just fine, Good looking tractor too :hide: Share this post Link to post Share on other sites
fourwheels0 191 #6 Posted June 1, 2011 cool. it cleaned up nice too. it looks better now than in the pic lol. Share this post Link to post Share on other sites
fourwheels0 191 #7 Posted June 1, 2011 cody. you have 50 horses? from the looks of your sig. holy crap. now i know where they all went hahaha. Share this post Link to post Share on other sites
Cody 285 #8 Posted June 1, 2011 Yes there's around fifty, i haven't updated my signature in a while but i have added a few more tractors sense. I have a two story barn full from top to bottom, three large two car garages full and probably 10-15 tractors sitting outside. I need to invest into a large pole barn soon. I also have a few farm tractors and a few john deere garden tractors. Share this post Link to post Share on other sites
fourwheels0 191 #9 Posted June 1, 2011 wow that's just amazing. i have just 2 but time will tell how many i get haha. here's the 12 with just a quick clean up. Share this post Link to post Share on other sites
tbbahner 28 #10 Posted June 3, 2011 Oh Oh Mike, looks like the BUG has bit you too! Nice old piece. By the way, got the crank. Thanks. Tom B Share this post Link to post Share on other sites
fourwheels0 191 #11 Posted June 3, 2011 ya tom i think i got bit . Share this post Link to post Share on other sites
fourwheels0 191 #12 Posted June 4, 2011 well i put the plow on the charger and found an issue. i can use the plow straight or turned to the right but not the left. if i try to turn it to the left the arm hits the footboard. i may cut a notch in the footboard. Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #13 Posted June 5, 2011 Try flipping the lever around so it angles forward. :hide: Share this post Link to post Share on other sites
Kelly 1,038 #14 Posted June 5, 2011 Take the handle off and turn it around so the notch faces the running board, you may have to tweek the handle some but it should fit, you will have to turnm the hardware on the handle around also. We must have been typing at the same time TT Share this post Link to post Share on other sites
fourwheels0 191 #15 Posted June 5, 2011 oh man DUH. that makes sense now that i look at it. i just put it on the same way it came off my c-81. the po must have put it together backwards. it worked on the c-81. i'll switch it over in the morning. thanks guys. Share this post Link to post Share on other sites
Kelly 1,038 #16 Posted June 5, 2011 Some tractors it goes the other way, or at least works that way. Share this post Link to post Share on other sites
fourwheels0 191 #17 Posted June 5, 2011 well turning the handle and hardware around didn't work. the wire that controls the blade angle hits the pto. it wouldn't fit with the wire guide on so i took it off and now it hits the pto. plus the handle is way too far forward.i almost have to get off the seat to reach it lol. hhmm well i either notch the footboard and turn the handle back around or keep the plow on the c-81. thanks guys. i'll figure out what to do before winter. Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #18 Posted June 5, 2011 What rear hitch are you using? (to attach the dozer blade frame to the tractor) Share this post Link to post Share on other sites
can whlvr 994 #19 Posted June 5, 2011 i would fab up a new arm for the blade before cutting your floor board,ive made arms for a few blades with an angle grinder and a welder,just a thought,or alter your existing handle Share this post Link to post Share on other sites
fourwheels0 191 #20 Posted June 5, 2011 What rear hitch are you using? (to attach the dozer blade frame to the tractor) hhmm i'm not sure. i'll take a pic so you can see it. here's the pic. Share this post Link to post Share on other sites
Cody 285 #21 Posted June 5, 2011 I would flip your hitch around because it is on backwards. Share this post Link to post Share on other sites
fourwheels0 191 #22 Posted June 5, 2011 ok i turned the hitch around and i still can't turn the plow to the left. no big deal i'll leave as-is for now. i can still plow straight and to the right. watch now we won't get any snow for a couple years . thanks for the tips and info. Share this post Link to post Share on other sites
