WVHeep 0 #1 Posted May 31, 2011 Picked up a B-112 yesterday, and the blades don't have a lot of life left in them. Does anyone know the part # so I can find a new set. Thanks. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,372 #2 Posted May 31, 2011 What deck do you have? 36" rear discharge 3-blade 36" side discharge 3-blade 37" side discharge 2-blade 42" rear discharge 3-blade 42" side discharge 3-blade Any model number on the deck? What size is the center mounting hole? Garry Share this post Link to post Share on other sites
WVHeep 0 #3 Posted May 31, 2011 It's a 2 blade side discharge. So I guess it is a 37"? I'll have to wait til I'm home from work tomorrow to get a model # off the deck. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,372 #4 Posted May 31, 2011 Your deck should be (1981-1982 05-37MS01) or (1983 05-37MS02) Toro 108004 Kit 2-blade Standard 37in. SD (1981-1982 05-37MS01) (1983 05-37MS02) (1983 A5-37MS02) (1982 LT-1137 5-speed A2-113701) (1982 LT-1637 Twin 5-speed A2-163701) {1981-1983} 1981-1983 (Napa na) (Oregon na) Hole 5/8in.x3/4in. Double-D 18.750in. 18-3/4" long? Guess Toro 108846 Blade Right high-lift blade Replaces right 108004 when used with bagger Replacement lift tab 105194 37in. SD (1981-1982 05-37MS01) (1983 05-37MS02) (1983 A5-37MS02) (1982 LT-1137 5-speed A2-113701) (1982 LT-1637 Twin 5-speed A2-163701) (1986 07-06BC01) (1986 07-06BC02) (1988 07-07BC01) (1988 07-07BK01) (1988 07-07BK02) (1987 37-06BL02) (1988 37-07BL01) (1984-1985-1986 07-06BX01) (1987 07-06BX02) (1981 07-06CX01) {1981-1988} 1981-1988 (Napa na) (Oregon na) Hole 5/8in.x3/4in. Double-D 18.75in. 18-3/4" long? Guess Garry Share this post Link to post Share on other sites
