dmoore 962 #1 Posted May 30, 2011 I ordered two new wheels for the rear of my 1979 42" side discharge deck from Mowparts.com...the original part #106588 had changed to #106557....upon receipt of the wheels I noticed they did not have the built in simple bearing on each side of the wheel...the original special shouldered bolt will not work with these wheels since the replacement wheel spins on a bolt not a bearing....Are there mounting bolts that go with these newer wheels? Thanks! D Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted May 30, 2011 :hide: #106557 is a reflector for the rear fender. Anyhow....... #110506 looks like the newest number for the correct gauge wheels for your particular mower deck. (and a bunch of other applications as well) That number replaces the following: 103665 106022 106588** (original on your 1979 deck) 108522 109037 2663 2877 4121 4480 5169 5305 6384 Check that number again & I'll see what I can dig up. :WRS: Share this post Link to post Share on other sites
dmoore 962 #3 Posted May 30, 2011 Doooooh! I looked at my order sheet wrong, you are right,it is 110506......D Share this post Link to post Share on other sites
dmoore 962 #4 Posted May 30, 2011 Looks like someone is selling the bolt on Ebay, item #380321455469....maybe these are what I need to go with my "newer" wheels? D Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #5 Posted May 31, 2011 I actually have a few "in stock" if you'd like measurements. I'm pretty sure you can also find them at Lowe's, Tractor Supply, ACE Hardware, small engine / L&G equipment repair shops, etc. They're basically just a push mower wheel bolt. :hide: Share this post Link to post Share on other sites
dmoore 962 #6 Posted May 31, 2011 My gage wheel bracket is not threaded...are nuts & spacers used with those bolts? Measurements would be much appreciated! D Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #7 Posted May 31, 2011 The shouldered section is .500" diameter X approximately 1.710" long. Threads are 3/8"-16 X roughly 13/16" long. The hex head is 3/4" and approximately .1875" thick. No spacers or washers are used - just a nylock (or equivalent) lock nut. Share this post Link to post Share on other sites
dmoore 962 #8 Posted May 31, 2011 I'll check your measurements against mine today....when I tightened up the 3/8" nylock nut the wheel will not move.....I would think the bolt would be stationary allowing the wheel to rotate on it? There are grease fittings on the wheels. D Share this post Link to post Share on other sites
dmoore 962 #9 Posted June 1, 2011 Ok, I never knew a guage wheel bolt could be so damn complicated! Here is my original...shoulder is 1/2" dia,length 1 5/8"...overall length is 2 5/8"...threaded length 3/4"...hex head 3/4"...1/4" thick.....its obvious this bolt WILL not work with the newer deck wheels.......Does ANYONE know the part number for the CORRECT bolt???? :hide: Share this post Link to post Share on other sites
oldredrider 2,553 #10 Posted June 2, 2011 Go to Lowes: 2 pack of adjustable bolts (in lawn mower section) for $2.99. Can't beat it and they work great. :hide: Share this post Link to post Share on other sites
dmoore 962 #11 Posted June 6, 2011 Found the right bolts Friday...the shoulder needed to be just 1/8" longer so when it was tightened up the wheel would actually spin....thanks for the suggestions & replies...D Share this post Link to post Share on other sites
