G-PAs Toy 0 #1 Posted May 22, 2011 It is in a Work Horse 700. It is a Tecumseh and I think I have been told it was a H60, but can't remember. It gave up on me last summer. I tore it apart yesterday and found the connecting rod had broke. Other than a lot of carbon build up on the valves and piston the old motor looked pretty good inside. Are parts like that still available? Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted May 23, 2011 We have a vendor here that has some Tecumseh parts, check there and if the orig. engine it should be a 7hp there should be a ID tag bolted to the block below the exh. port, and another on the blower housing, that one will have a set of numbers like H60, HH60 or H70, HH70 look for that. Share this post Link to post Share on other sites
MikesRJ 563 #3 Posted May 23, 2011 If the engine is original it would be a H70-130042 or a H70-130043. Here's a general service manual for the Tecumseh which might help you. http://www.mywheelhorse.com/graphics/file/...vice-Manual.pdf http://www.mywheelhorse.com/graphics/file/...ecumseh_BSI.pdf Share this post Link to post Share on other sites
G-PAs Toy 0 #4 Posted May 23, 2011 I found the tag, it is a H-70. Try to get the rest of the numbers a little later. Thanks guys. Who is the vendor? Share this post Link to post Share on other sites
