elixir20 1 #1 Posted May 18, 2011 OK guys, I am beginning the refurb of my 702 tractor. Starting with the motor and see where that takes me! As for history, it did not come with any since the PO never had it running. I know the starter spins (after hooking up to a battery pack) and it has compression. It did not come with a coil wire. I figure I'll need at a minimum a fuel pump kit, coil wire and points. Anyone care to add to this? How about good part sources? As mentioned, it is a K161S Spec 28626E Serial 546180. Mechanical ability has never been my strong suit, so any hints tips and prayers are welcomed. :hide: Share this post Link to post Share on other sites
Coadster32 793 #2 Posted May 19, 2011 Here is a list of links. You should find what you need for parts, and manuals there. Don't forget to use the search function, as most common questions have been answered in previous posts. (a little homework goes a long way). Good luck on the rebuid. http://www.wheelhorseforum.com/index.php?showtopic=143 Share this post Link to post Share on other sites
