privateer 1 #1 Posted May 16, 2011 nothing but trouble for me with the pulley drive on my c-120 over the weekend. In hindsight I should have just replaced the belt.... I needed to adjust the tensioner since the belt was slapping and starting to slip under load from the grass growing at a rediculous pace. First go to adjust the tensioner knob after some pb blaster soaking knowing the bolt might be locked up. Snap the bolt at the pin p/n 101842. I finally get the bolt free and tighten it up a bit. Low and behold the pulley -V 104974 blows to bits. I'm sure the pulley flat idler is next to go. Anyone out there have an extra front attach-a-matic for sale in decent shape? As it stands now I'm out some decent coin to replace the two pulleys and the rod adjustment bolt. Any help appreciated and thanks for reading Rich Share this post Link to post Share on other sites
Irv 115 #2 Posted May 16, 2011 there's a few mule drives on ebay. Share this post Link to post Share on other sites
Horse Lover 0 #3 Posted May 17, 2011 Are these bearings replaceble cause my inner bearing is howling pretty bad and there is no Napa dealer close :hide: Share this post Link to post Share on other sites
smoreau 658 #4 Posted May 17, 2011 look in the for sale section of RS, there was a few for sale not that long ago. Share this post Link to post Share on other sites
fdsinozich 1 #5 Posted May 17, 2011 My V pulley blew out a week ago and one of our own had both pulleys with good bearings. Check with Dave. daveoman@windstream.net. He might also have the mule drive. Frank Share this post Link to post Share on other sites
BOWTIE 226 #6 Posted May 17, 2011 Some of the pto pulleys you can remove the seal with a little srcewdriver (BE CAREFUL) you are going to reinstall. I wash them out and repack them with grease and reinstall the seal. This only works if you catch them early. Good luck Share this post Link to post Share on other sites
refracman 167 #7 Posted May 17, 2011 You dont have to remove the seal on a nongreaseable bearing. Go to NAPA and get the needle adapter for your grease gun. On the pullies if you find a set pullies for the pre mule drive decks the pullies are cast and the bearings are replaceable, they fit in the mule drive and you never have to replace them again! Share this post Link to post Share on other sites
SgtBob 27 #8 Posted May 18, 2011 Rich, PM sent ! Thanks, Bob Share this post Link to post Share on other sites
tunahead72 2,658 #9 Posted May 18, 2011 You dont have to remove the seal on a nongreaseable bearing. Go to NAPA and get the needle adapter for your grease gun. On the pullies if you find a set pullies for the pre mule drive decks the pullies are cast and the bearings are replaceable, they fit in the mule drive and you never have to replace them again! Seriously? I never knew these were options, please tell us more. Like, what's a needle adapter, and how do you use it on one of these nongreasable bearings, and can it be used anywhere else besides the pulleys on the mule drive? And, do you have parts numbers for the cast pullies with replaceable bearings that would replace the 104974 & 104975 pullies on the mule drive for my 42" side discharge mower? And how do you replace the bearings on these? :hide: Share this post Link to post Share on other sites
refracman 167 #10 Posted May 18, 2011 The grease needle adaptor is availble from good auto parts outlets for about 5-7 dollars and can be used on most nongreasable bearings. Just weasle it under the seal and a couple of pumps its good to go. The pullies are part #s 6740 and 4974, bearing #4567, used on some 36" and all 42"-48" decks from 69 to 72, You can find these pullies easy enough at swap meets, and the bearing either thru toro or your local supply house. Bearings are held in place with a snap ring, very easy to replace. Share this post Link to post Share on other sites
tunahead72 2,658 #11 Posted May 18, 2011 Steve, Thanks very much for all this information -- I've been told for 24 years that these pulleys can't be greased, and have to be replaced with the same kind when they start screaming, it's nice to know we have other options. Thanks again! Share this post Link to post Share on other sites
shorts 182 #12 Posted May 19, 2011 someone like McMaster-Carr or Motion Ind. should be able to procure pulleys with replaceable bearings :WRS: Share this post Link to post Share on other sites
The Toolman 22 #13 Posted May 19, 2011 If these guys don't have it, (pulleys) I bet its not made then http://www.phoenix-mfg.com/acatalog/Replacement_Pulleys.html Share this post Link to post Share on other sites
privateer 1 #14 Posted May 19, 2011 Thanks for everyones input and help. Problem solved! :hide: Share this post Link to post Share on other sites
