TOPCOP 0 #1 Posted May 14, 2011 :hide: THE BREAK PEDAL ON MY C 195 STAYS STUCK DOWN UNTIL I PULL IT BACK UP, I HAVE LUBED EVERY PLACE I COULD FIND ON IT AND IT STILL STICKS. I DID NOT USE IT FOR SEVERAL MONTHS AND WHEN I DID I FOUND THIS PROBLEM AND ALSO THE TRANNY DOESN'T STAY IN FOWARD UNLESS I HOLD IT. ANY HELP THANKS TOP COP. :WRS: Share this post Link to post Share on other sites
refracman 167 #2 Posted May 14, 2011 Check the return spring also oil/grease the pedal. Share this post Link to post Share on other sites
buckrancher 2,695 #3 Posted May 15, 2011 there is a friction adjustment on the top of the trans by tighting a nut for your motion lever not staying forward Share this post Link to post Share on other sites
Kelly 1,033 #4 Posted May 15, 2011 I just today working on a C-195 I picked up a while back, the brake pedal would hardly move and if it did I had to pull it back, I had the center console cover off and the pivoit point inside the console was the problem I worked some PB blaster in to it, and all is good, works very smooth now, and I also had to tighten the friction bolt up about a 1/8 of a turn to keep a steady speed. Share this post Link to post Share on other sites
TOPCOP 0 #5 Posted May 17, 2011 :hide: Thank you all, followed all the suggestions, the brake is free and the shifting is like it should be. I mowed the back 40 with it with no trouble. :WRS: Share this post Link to post Share on other sites
