The Toolman 22 #1 Posted May 11, 2011 I need to know if anybody has the # for my fuel pump from NAPA? For some odd reason they cannot find my spec# in their books. They are all around it, but just not my spec #. 241 AS Spec#46766D Ser 9662450 On a 79 C-101 8 speed I know about the rebuilding kits, but I just wanna go with the new plastic one. Its a work tractor now. Thanx, Ron Share this post Link to post Share on other sites
WH854 45 #2 Posted May 11, 2011 I need to know if anybody has the # for my fuel pump from NAPA? For some odd reason they cannot find my spec# in their books. They are all around it, but just not my spec #. 241 AS Spec#46766D Ser 9662450 On a 79 C-101 8 speed I know about the rebuilding kits, but I just wanna go with the new plastic one. Its a work tractor now. Thanx, Ron Kohler parts look up says the P/N is A-235845-S TO use A-235366-S on engine That is what I found!! There could be newer P/N for the plastic ones. I have the plastic pumps on my K242AS and K341S Chas Share this post Link to post Share on other sites
Butch 194 #3 Posted May 11, 2011 http://desc.shop.ebay.com/i.html?_nkw=A-23...&LH_TitleDesc=1 Share this post Link to post Share on other sites
WH854 45 #4 Posted May 11, 2011 A-235845-S will fit your engine :hide: Share this post Link to post Share on other sites
dmoore 1,023 #5 Posted May 11, 2011 I am at this cross road presently.....I originally had the "metal pump on my 78 C-101 8-speed K-241 but it went out several years ago...after I installed the new "plastic" one the engine really took a long time starting...I'm guessing the plastic pumps do not have the check valve like the original metal ones.....anyone else experience this? Share this post Link to post Share on other sites
WH854 45 #6 Posted May 12, 2011 I am at this cross road presently.....I originally had the "metal pump on my 78 C-101 8-speed K-241 but it went out several years ago...after I installed the new "plastic" one the engine really took a long time starting...I'm guessing the plastic pumps do not have the check valve like the original metal ones.....anyone else experience this? Did not have that slow starting problem. My k341S and K241AS fires after the firt couple spins thank goodness Chas Share this post Link to post Share on other sites
WH854 45 #7 Posted May 12, 2011 If I shut the gas valve on the tank off and run the gas out of the lines and carburater,it takes a bit longer to get gas pumped into the carburater. Chas Share this post Link to post Share on other sites
