puddlejumper
deck belt
puddlejumper
Could somebody give me the deck drive belt dimensions for a 308-8 with a 36 inch deck. And Maybe a quick lesson on how to look it up myself all I can find is tractor Info and parts but nothing on the deck.
Thanks guys
dgjks6
If it is the 36 inch deck then the deck from the tractor to the deck is part number 102741 and is a v belt 96 1/2 inches by 1/2 inch
The belt on the deck is 8411, it is a v-belt, and is 1/2inch by 77 inches.
The 36 inch deck has 3 pulleys - it is set up similar to the 42 and 48's just smaller.
Is that what you are talking about or do you have the 37 inch deck (has 2 pulleys and a weird hex belt from the PTO that directly drives the pulleys)
You can get all of the info from the toro master parts viewer under attachments.
puddlejumper
I have the 37 with the hex belt. Thought it had just been run wrong and wore that way. Thanks
