mattd860 162 #1 Posted May 7, 2011 I got a moldboard plow for my tractor but it didn't come with the front 'disc'. Is it absolutely necessary to have this or can I plow without it? Share this post Link to post Share on other sites
Indy w h 4 #2 Posted May 7, 2011 Well it depends on 2 things : 1- are you cutting sod ?? 2- are you turning over dirt in a garden that's been worked before?? Share this post Link to post Share on other sites
mattd860 162 #3 Posted May 7, 2011 Well it depends on 2 things : 1- are you cutting sod ?? 2- are you turning over dirt in a garden that's been worked before?? Sod Share this post Link to post Share on other sites
Indy w h 4 #4 Posted May 7, 2011 Well it will do it but the cutter disc is what "cuts " the sod so it will turn Some soils are tougher than others So give it a try Share this post Link to post Share on other sites
6wheeler 586 #5 Posted May 8, 2011 The plow will work without a coulter. But in sod that hasn't been worked before it will want to rip and it may pull a little harder. Share this post Link to post Share on other sites
