lillbiker 0 #1 Posted May 3, 2011 i have a wheel horse had no luck yet it is a 3 speed with a hi and low it has a 10 hp engine on it has a 42 in. deck rear discharge runs with pto and has tach-o-matic it has a small handle about 12 in. that engages deck blade. what model and year is itit says 310-8 on it something doesnt look right Share this post Link to post Share on other sites
tunahead72 2,347 #2 Posted May 3, 2011 Can you read the VIN plate? It should be located on the rear fender, either in front of the seat or to one side of it. Can we assume you mean 2 speed ranges, each with 3 forward gears plus reverse? Kohler K-series (K-241) or Magnum? What exactly doesn't look right? Photos would help a lot. -------- Just saw your earlier post about your 21-10K801 -- same machine? That would be a 1985 model. And :thumbs: Share this post Link to post Share on other sites
C-Series14 15 #3 Posted May 3, 2011 Well, if it has high and low ranges, it is an 8-Speed. Also, if it says 310-8 then that is what it is. Share this post Link to post Share on other sites
lillbiker 0 #4 Posted May 3, 2011 thanks everyone hey does anyone have a pic. of how drive belt goes on Share this post Link to post Share on other sites
