trainman 0 #1 Posted May 2, 2011 Hello all I have a Wheel horse 211-5 lawn tractor, The rear tires are rusted on the axle i have soaked them well with wd40. I have removed the outer c- clips on the outer axle and washers and these wheels wont budge. I want them off due to the tubes wont hold air for a few days I think I need new tubes it was built in 1986. Any suggestions??? :thumbs: Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted May 2, 2011 There is no good way on those lawn tractors, DON"T pound on it to hard you will break the trans inside or pull a axle right out of it, the last one I did, I pulled the tire off the rim, then cut the rim off the center hub, then split the center hub along the shaft to get it off, but if your just needing to change a tire it can be do with the rim on the mower. Share this post Link to post Share on other sites
HankB 16 #3 Posted May 2, 2011 I don't know that WD-40 is a particularly good penetrant. I would get something like PB-Blaster or Kroil that has been formulated to do that. There were some messages going around last year that suggested that a 50:50 mix of acetone and ATF made a good penetrant. If you try that, use utmost caution because acetone is very volatile. (google "acetone ATF" for more discussion of that.) If you have time, let it work for you. I've had stuff that I couldn't budge come off easily after several weeks of application. As a matter of course, I shoot some penetrating oil on the rear hubs of my tractors on an annual basis. Hopefully should the need arise to remove the hubs, they will come off w/out too much fuss. I do the same with parts on mower decks that are known to be difficult to remove. I've seen this question too many times. Share this post Link to post Share on other sites
C-Series14 15 #4 Posted May 2, 2011 Wd-40 won't help....PB Blaster or Kroil would be better. I have though put new tubes and tires on a wheel like yours while on the tractor Share this post Link to post Share on other sites
perry 82 #5 Posted May 2, 2011 yep, leave the rims on and strip the tire while on the tractor. or pop the outer bead off and replace tubes. will have to still break both beads from rim to make it easyier to get the outer bead off rim. Share this post Link to post Share on other sites
dgjks6 6 #6 Posted May 2, 2011 Leave off the c-clip and washer. Put on some PB blaster. Try for several days to remove. Decide they are never coming off. Plan a party at your house. Let your lawn grow a little long. The day of the party, when the grass NEEDS to be cut and if you can't cut the grass at that time it would really be inconvenient, go try to mow. Then the tire will literally fall off. Works every time for me. Share this post Link to post Share on other sites
HankB 16 #7 Posted May 3, 2011 ... Plan a party at your house. Let your lawn grow a little long. The day of the party, when the grass NEEDS to be cut and if you can't cut the grass at that time it would really be inconvenient, go try to mow. ... I like that strategy. what are you serving at the party? :thumbs: Share this post Link to post Share on other sites
clintonnut 126 #8 Posted May 3, 2011 ... Plan a party at your house. Share this post Link to post Share on other sites
Kilroy 0 #9 Posted May 3, 2011 Leave off the c-clip and washer. Put on some PB blaster. Try for several days to remove. Decide they are never coming off. Plan a party at your house. Let your lawn grow a little long. The day of the party, when the grass NEEDS to be cut and if you can't cut the grass at that time it would really be inconvenient, go try to mow. Then the tire will literally fall off. Works every time for me. That is hilarious. Will keep that in mind though. :thumbs: Share this post Link to post Share on other sites
Arndts small engine repair 0 #10 Posted May 3, 2011 yep, leave the rims on and strip the tire while on the tractor. or pop the outer bead off and replace tubes. will have to still break both beads from rim to make it easyier to get the outer bead off rim. Yes i would leave the rims on and strip the tire while on the tractor ! i hate fixing trans when you pull the axles out ! but good luck :wh: Share this post Link to post Share on other sites
meadowfield 2,683 #11 Posted May 3, 2011 last sticky one we had, had the oxy acetylene to heat the wheel hub cherry red, used a punch to try knock the shaft whilst holding the wheel with the tranny suspended from the hub. Needless to say it didn't work... So we split the tranny and used the press 9 tons before the shaft moved with helluva bang!! mark * note this was a peerless and full of grease, so no seals to wreck Share this post Link to post Share on other sites
