gsxrinthe9s
new wheel horse cant find model
gsxrinthe9s
Picked up an old wheel horse and have some problems the decals are gone and can't find the model number here is what I know its a 10 HP kohler 3 speed with high and low range it has a coil with 3 wires going to it the gas tank is in the rear I have two problems I think the ignore switch is bad its a 5 prong but with not knowing the model I don't know what to get
Also I want to change the fluid in the trans its kinda milky looking but don't know what to use
Horse'n Around
Howdy :thumbs: If you could post some pictures of it and or provide the serial number it would be a lot easier to let you know what you have.
WH854
:wh: :thumbs: Look down under the dash It's Possible there is a tag there with VIN numbers I hope. Is the gas tank plastic?
Chas
JimD
Is the tranny a hydro or manual? If it's a manual, 80 to 140 weight gear oil should be used, I use 90 weight. I don't have any hydros, but someone here will know what to use. :thumbs:
C-Series14
It is a C-101 8-Speed...VIN on tag under steering wheel on flat plate will be 81- or 91-10k801
www.sepw.com to get the parts diagram.
WH854
You can go here to get a parts break down also :thumbs:
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro
Or here for 3 manuals for it.
Just put Mike's model # in both places like he has them writen.
Chas
gsxrinthe9s
Wow now that's what I call help my son found it it was painted over
81 10k 801 02705
C-Series14
Ok...so 81-10K801 is a 1978 C-101 8-Speed. Also, the serial number is 02705. Under those numbers is another number, it is the manufacture date, a 4 digit number.
It is an awesome tractor because...it is a C-Series!!! :thumbs:
gsxrinthe9s
Mike I see you live in Sw Ohio how far from Ross Ohio
I'm trying to add some picks
C-Series14
I am near Washington Court House....
c175inMA
:thumbs:
gsxrinthe9s
Hey I want to thank everyone for the help. Can't believe how many people jumped in with suggestions hopefully when I am as well versed with all the wheel horse. Models I will be able to contribute as well.
can whlvr
