temler 0 #1 Posted April 27, 2011 I am just looking for a part to get my WH working again, I am looking for part number 103081 it is the front bearing flange for the rear PTO shaft, one half of it is just wore clear through, I thought about trying to beat one out of some metal, is that something that might work since they (toro) say the part is no longer available. The bearing seem to be running real smooth so i think all i need is this, the PTO shaft lost a bolt out of the second back bracket and i didn't know it so that is probably shy the flange is wore out and i also noticed that the bearing was put in backwards maybe that is why it is shot. let me know if anyone has made there own or maybe something else that might work. or where the new part is. or just something to get it running again. Thansk Tim from OH Share this post Link to post Share on other sites
WH854 44 #2 Posted April 27, 2011 Would help if you tell us what tractor you are needing parts for and location!!! Chas Share this post Link to post Share on other sites
rmaynard 14,945 #3 Posted April 27, 2011 Searching the part number, it appears to be for the rear PTO for a 1974 and 1975 D-160, D-180, D-200 automatic. Share this post Link to post Share on other sites
WH854 44 #4 Posted April 27, 2011 Try Tractor Supply Company I have seen flanged bearings there(just a thought) Chas Share this post Link to post Share on other sites
boovuc 1,090 #5 Posted April 27, 2011 Hi Tim, Try McMaster-Carr. Since you have the WheelHorse/Toro number, if you can get some specifics on the bearing, they can most likely get a replacement for it. BooVuc Mill Hall, PA Share this post Link to post Share on other sites
Kelly 1,028 #6 Posted April 27, 2011 If it's the one I think you need, try TSC, they have the tin bearing holders, used for many things, but take your old one to match it up, I had to get some for snowblower bearings, and picked some up and new bearings for my sweeper all from TSC. Share this post Link to post Share on other sites
KB9LOR 4 #7 Posted April 29, 2011 I got this from wheelhorse.org, thanks to gwest_ca..... Garry, it is what you need. Joined: Fri Dec 17, 2004 8:01 am Posts: 1936 Here is what I was thinking may work and be easier to find locally http://www.mcmaster.com/# Search for 5968K75 You can get them with a locking collar so the bearing is sure to turn with the shaft. Share this post Link to post Share on other sites
