cubguy 0 #1 Posted April 18, 2011 I am installing a foot control kit on my 520H. The top of the pivot arm that attaches to the pedal is rubbing on the bottom of my transmission drive belt. Has anyone seen this or have a fix? The belt does seem a little loose, but I am not sure if the tensioner pulley is adjustable or not. Thank you, Guy Share this post Link to post Share on other sites
littleredrider 408 #2 Posted April 18, 2011 Dunno on rubbing, but where did you get the conversion?? Need one for mine.... Share this post Link to post Share on other sites
DOC in Kentucky 178 #3 Posted April 18, 2011 Sorry Guy but I can't help you as I have never installed one on a 520 but I have sold 5 or 6 of these to be installed on the 520 model. Try sending an e-mail to Jim M or Zeig72, I know they have them installed and working. Or just search "foot control" posts over 30 days old and you will see a few threads discussing the install on the 520 model. Share this post Link to post Share on other sites
B-8074 19 #4 Posted April 18, 2011 I have one I got from DOC it's on my C-175 and the belt dosen't rub. I would check the idler pulley tension spring. If the belt is flopping when the tensioner is on you may need a spring. Share this post Link to post Share on other sites
refracman 166 #5 Posted April 18, 2011 My 195 is doing the same thing. I believe it has to be because the motor is in a different position because of the longer frame. I havent gotten into it. Might have to reposition the foot control stand closer to the motor. When these came in the 70s out they were for the standard C series and probably never cahnged after that. Share this post Link to post Share on other sites
