Coadster32 793 #1 Posted April 11, 2011 Hey all. My nephew just got in a 606 after drooling over my 854 plowing duties this past winter. The tranny is freed up, as is the motor and the cutting deck that came with it. The question I have is that the dash plate has the empty spot and writing for the lights and electric start. Obviously it has neither, and the key is just run or off. Did someone switch the dash plate, or did they come like this and just remind you of what you could have bought. (I think it was switched). Also, I'm thinking it would use a 42" short frame snow bozer blade. I'll be looking for a plow, and a belt guard for it. Perhaps a new flywheel to add electric start to it as well. Share this post Link to post Share on other sites
mr.pipes 4 #2 Posted April 11, 2011 I think the only difference between the 606 and 656 is the features you mentioned. I have a 606 and I think it had a couple of those chrome push plug things. Plumbers call them Cock Hole Covers. I could take a look again sometime and double check. Share this post Link to post Share on other sites
wheelhorse656 20 #3 Posted April 11, 2011 I think the only difference between the 606 and 656 is the features you mentioned. I have a 606 and I think it had a couple of those chrome push plug things. Plumbers call them Cock Hole Covers. I could take a look again sometime and double check. you are absoulutly right!!! same dash just with those crome hole plugs. they can be bought brand new at lowes for around 2.00 each. Share this post Link to post Share on other sites
dclarke 4,011 #4 Posted April 11, 2011 Chris, i have a dash plate from a "606" that has a couple of hole plugs in it. my guess is they came that way new. p.m. sent on the belt guard. Share this post Link to post Share on other sites
Kelly 1,028 #5 Posted April 11, 2011 My 656 had the plug in the hole for the lighter, I swaped engines and have the belt guard for the tucky if you need one. Share this post Link to post Share on other sites
Coadster32 793 #6 Posted April 12, 2011 Thanks for the reply guys. I have to admit, I thought Wheel-Horse wouldn't put a dash on that didn't belong, but I guess I'm off a bit on that. I appreciate the belt guard replys as well, and will hook up with Denny on that. (Thanks anyway Kelly). :thumbs: Share this post Link to post Share on other sites
