P3x 57 #1 Posted April 1, 2011 Looking at Mid Mount Graders and would like to find out which Part/Model Numbers will fit a '93 520H. For example, will a Grader Model Number 79356 designated for a 520XI fit my 520H? I checked the Attachment Interchange Document and the 79356 is not specified as fitting the current/latest Model Number listed for a 520H (79531). Thanks to the board for sharing your knowledge and preventing me from wasteful spending! P3x in Mass. Share this post Link to post Share on other sites
dennist 139 #2 Posted April 1, 2011 I am sure some others will help out, but I believe the grader blade that fits the xi series will not fit your 520H. I also believe your second number(79531) that you have listed may have a couple numbers backwards as the numbers on mine are 79351, although they may be both correct. :thumbs: Share this post Link to post Share on other sites
Kelly 1,035 #3 Posted April 2, 2011 I put a 50" mid grader from a XI on my 520, but stock you can not angle it, the rear part of the frame is to long, sets the blade forward to far, I removed the rear mounting bar, and cut about 4" off the rear frame drilled new 3/4" holes put the mounting bar back in and welded it, works fine now. I may have pictures if you need them. Share this post Link to post Share on other sites
P3x 57 #4 Posted April 3, 2011 You are correct dennist I transposed the numerals should be 79351. Thanks for the offer Kelly. In the interim, I found the correct grader numbered above so won't be looking at the Xi grader. Learnin' more all the time... Share this post Link to post Share on other sites
