danjmah 74 #1 Posted March 30, 2011 I purchased a 1988 414-8 with a 48" SD deck 05-48MS05 a couple of weeks ago and was trying out the deck yesterday and noticed the center pulleys grease zerk rubbing against the bar lift? The deck works great but from what I see so far all looks to be installed correctly except for this. When the deck height is adjusted to a higher setting is when the grease zerk has touched the bar lift. Is this thing bent or is something missing? thx Share this post Link to post Share on other sites
Kelly 1,037 #2 Posted March 30, 2011 I've seen many touching or very close, pull the deck off, look at the back of the T bar the cross shaft lots of times is bent, you can pull the C clip on on side and remove it to repair it. Share this post Link to post Share on other sites
B-8074 20 #3 Posted March 30, 2011 It might be. Make sure that the deck is in the mid mount on the the tractor correctly. May not be centered. :thumbs: Share this post Link to post Share on other sites
WH854 45 #4 Posted March 31, 2011 Looks like some one had that problem before look here. http://www.wheelhorseforum.com/index.php?showtopic=4319 Chas Share this post Link to post Share on other sites
danjmah 74 #5 Posted March 31, 2011 Thanks All. this helps greatly. Share this post Link to post Share on other sites
