scv85 1 #1 Posted March 29, 2011 I am currently restoring a 70 GT14. I got into the parking brake a bit and I found the pulley has a bad bearing. It looks like someone put a shorter belt on to bypass having to use the pulley. Does anyone know where I can get a pulley for the parking brake and does anyone have a diagram? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted March 29, 2011 (some) Parts are available at your local Toro dealer or online. Here's the parts list: http://www.partstree.com/parts/?lc=Toro+Consumer&mn=1-7451 Share this post Link to post Share on other sites
scv85 1 #3 Posted March 29, 2011 Excellent!!! The picture is the exact same as my parking brake setup. Someone definitely put a smaller belt on. I'll order up a pulley and a belt! Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted March 29, 2011 You should also be able to find the part numbers for the tranz seals on that same site. Share this post Link to post Share on other sites
scv85 1 #5 Posted March 29, 2011 I tried to find those but the diagram will unfortunately not load for the trans. Are you able to get the part number from yours? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #6 Posted March 29, 2011 Axle seals should be OEM P/N 6449 (or SKF 11124) Share this post Link to post Share on other sites
scv85 1 #7 Posted March 29, 2011 Ah ha! Right again, I measured the shafts at 1 1/8". That was all the info I had, picture wouldn't load for some reason. I really appreciate all your help. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #8 Posted March 29, 2011 The Toro MPV does have the tranz IPL Go here: https://lookup3.toro.com/partdex/index.cfm?...es&xCaller=Toro Click on "Model Search" (in the green area near the top) and enter 1-7451 in the box. (select "Assembly Drawings" on the next page that opens) Share this post Link to post Share on other sites
