scv85
GT14 Parking Brake
scv85
I am currently restoring a 70 GT14. I got into the parking brake a bit and I found the pulley has a bad bearing. It looks like someone put a shorter belt on to bypass having to use the pulley. Does anyone know where I can get a pulley for the parking brake and does anyone have a diagram?
scv85
Excellent!!! The picture is the exact same as my parking brake setup. Someone definitely put a smaller belt on. I'll order up a pulley and a belt!
TT
You should also be able to find the part numbers for the tranz seals on that same site.
scv85
I tried to find those but the diagram will unfortunately not load for the trans. Are you able to get the part number from yours?
TT
Axle seals should be OEM P/N 6449 (or SKF 11124)
scv85
Ah ha! Right again, I measured the shafts at 1 1/8". That was all the info I had, picture wouldn't load for some reason. I really appreciate all your help.
TT
The Toro MPV does have the tranz IPL
Go here: https://lookup3.toro.com/partdex/index.cfm?...es&xCaller=Toro
Click on "Model Search" (in the green area near the top) and enter 1-7451 in the box. (select "Assembly Drawings" on the next page that opens)
