redtin 0 #1 Posted March 25, 2011 Hi Can anyone say if a C series 8 speed trans will fit a 416 they look the same except for a slight kick in the gear arm and would the parts interchange. Redtin :thumbs: Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted March 25, 2011 Don't know what you mean by gear arm?? unless that is the shifter? but the trans should be a bolt in, check axle sizes some C's used the small 1" axle but still will fit just needs to have hubs on it. Share this post Link to post Share on other sites
Anglo Traction 761 #3 Posted March 25, 2011 If your C series Tranny is a 103916 model, then the main difference between that and your 110996 appears to be the Diff. C was predominately 8 pinnion and the 416 4 pinnion (86 model). It would help if you can say what Tractor model the 'C' Tranny came from and if it was original. Should be able to interchange most parts. Share this post Link to post Share on other sites
redtin 0 #4 Posted March 25, 2011 Thanks for reply Kelly The one spare trans I have has 1-1/8" axle and came I was told from a C series always thought they were 1 1/8" as my 416 it has 1-1/8 axle I thought all 1-1/8 axle were 8 pinion, the C series has a strait shifter but 416 has a kick lower down. Redtin Share this post Link to post Share on other sites
redtin 0 #5 Posted March 25, 2011 Hi ANGLO TRACTION Is that ID No stamped on the trans as have no other info could post pic if required just told it came fron a C series. Share this post Link to post Share on other sites
Anglo Traction 761 #6 Posted March 25, 2011 The one spare trans I have has 1-1/8" axle and came I was told from a C series always thought they were 1 1/8" as my 416 it has 1-1/8 axle I thought all 1-1/8 axle were 8 pinion, the C series has a strait shifter but 416 has a kick lower down. Redtin You've answered my query, as you don't know which 'C' it came from. So, if you want to just swap it into the 416, no issues, just change the Gear Shifter to fit the Tin Work on the 416 if needed. If you want to swap parts, the only difference you'll (probably) find are the Diff pinnions, but the Diff should be interchangable as a unit. There are no markings on the Trannys to I.D. them. Regards Share this post Link to post Share on other sites
redtin 0 #7 Posted March 26, 2011 Thanks again Anglo Traction. Yes stamped on the Tanney are some numbers but as you said don't seem to mean anything,there is no Unidrive label on it it's OK except a job to get in third gear bearings seal's seem good so not sure if strip down is necessary Redtin Share this post Link to post Share on other sites
