Horse Lover
84 310-8 Trans surges in Hi only
Horse Lover
Theres no grinding sounds,pulls fine. Just rocks back an fourth while mowing, I'm worried I'm gonna spill my beer :thumbs:
Duff
Huh? :thumbs:
Don't quite understand the symptom. Are you sure it's not just the engine surging? In low range it wouldn't be as noticeable in terms of motion as in high range. :thumbs:
Duff :thumbs:
Kai Thomsen
Had a tractor once that did the same (not a WH)
There was two things wrong:
The input pulley on the transmission was loose and the key in the shaft had worn out the pulley, and one of the hubs was worn too, the axle could turn almost 1/4 turn before it would "catch up" with the hub.
It felt just like the tractor would jump in and out of gear while mowing.
Horse Lover
Yep thats the same thing this one is doing.
Forest Road
The drive belt is probably worn out. Change the belt and hold on tight!
Horse Lover
I bet the original one is on there. the last owner didn't take very good care of this thing. Hood hinges are egg-shaped. :thumbs:
SNYFIX
Go for your hubs as someone mentioned. They're wallered out along w/the axle key and possibly the axle keyway as well. You might get lucky tho and just need a hub tight'in up !!
