boovuc 1,090 #1 Posted February 28, 2011 Guys, I aquired a rear discharge 42" deck from a guy who had it along with his blown 312-8 speed sitting outside for three years. The deck itself needs a spot welded on the right rear side but remarkably, the rest of the deck is very sound. I can't make out the model number but I would guess its an 05-42MR04 since the tractor is that vintage. (Non-Magnum 12HP Kohler in it). Can someone supply me with spindle replacement numbers and the spindle belt replacement. I can't find a parts diagram for this deck. Also....it used to have "something" along the rear discharge as I have several empty bolt holes along the back of it. Any concerns? Thank, BooVuc Mill Hall, PA Share this post Link to post Share on other sites
racinfool40 202 #2 Posted February 28, 2011 might try the link below has alot of good info http://www.mywheelhorse.com/graphics/file/...PL_810172R1.pdf Share this post Link to post Share on other sites
mrocket49 23 #3 Posted March 1, 2011 Those holes at the rear of the deck are for an optional discharge deflector. I have one on mine but it doesn't seem to make much of a difference in the clipping pattern. 1 Share this post Link to post Share on other sites
boovuc 1,090 #4 Posted March 1, 2011 Thanks Guys, I did get some numbers off Parts Tree. Someday I'll learn to put the damn dashes in the model numbers! RacinFool............thanks for the pdf parts list. That is handy for all my decks! I wondered about the empty bolt holes. My old 857 RM rear discharge deck didn't have anything behind it and it seems to work OK. Thanks again for your replies. BooVuc Mill Hall, PA Share this post Link to post Share on other sites
