118lfd 8 #1 Posted February 19, 2011 I have a 37" 05-37SC01 mower deck for my 310-8 I am trying to replace all the bearings on it. I have done the spindle bearings but the idlers have to be replaced and I can't seem to figure it out. It has the six sided belt that runs from the pto to the deck. I have 2 v belt pulleys on the mule drive and 2 v belt pulleys on the deck. I need the part number for the ones attached to the deck. The master parts viewer shows a flat and a v. Not what I have. Also it shows the pulleys only, but mine have spacers in them.Please help me get the right cause the pulleys range from 8 to 58 dollars. :thumbs: Share this post Link to post Share on other sites
rick 217 #2 Posted February 19, 2011 37" deck with six sided belt uses v pulleys. Use two of the part number for the v pulley, 111170. Mine had no spacers, only the washers between the pulleys and the deck. Share this post Link to post Share on other sites
MikesRJ 552 #3 Posted February 19, 2011 Try this ... http://www.mywheelhorse.com/graphics/file/...D_05-37SC01.pdf Share this post Link to post Share on other sites
118lfd 8 #4 Posted February 22, 2011 A little reasearch and I found a Stens 280-287 with the same specs and only 15.00 ea I will give them a shot. 1 Share this post Link to post Share on other sites
118lfd 8 #5 Posted February 25, 2011 Got the pulleys today. Absolutely the same pulley. Except the color. The bearings inside are the same part number. 15.00 each sure beats 53.00 each Share this post Link to post Share on other sites
