IthacaJeff 151 #1 Posted February 15, 2011 WH'ers: Here is the dilemma: I've got a 416-8 and a 310-8. The 416 is my mower, the 310 the utility get dirty tractor (dozer blade, moldboard, drags, trailer, etc.). If I can get my tiller up and running for spring I've got a lot of chores for it, from a 40'x60' garden, loosening up soil to plant about 60 small trees, and even knocking down some high spots in the yard. Both tractors have turf tires, only the 310 has chains. I foresee these tiller tasks taking a while during mowing season. I'd rather not be switching the tiller and mower deck back and forth on the 416, so here are my options: --Run the 310 with the tiller. Leave the mower on the 416. --Run the 416 with the tiller. Put the mower deck (48" SD) on the 310. Some of you have said the 310 can handle the 48" deck (about 2 acres of level yard) --Don't be so lazy and swap the tiller and deck on the 416. What's your opinion? Thanks, Jeff in Enfield NY Share this post Link to post Share on other sites
can whlvr 994 #2 Posted February 15, 2011 i would run the 16 on tiller,u can use a 10 on tiller but its gonna work if u r breaking new ground,the 10 is gonna work on a 48 too,but it will do it,i have both those engine sizes,and i have done both duties on the 10 and if you keep on the grass it will do it ,if u were just breaking up a previously tilled garden only,then the 310 could till Share this post Link to post Share on other sites
Jim_M 179 #3 Posted February 15, 2011 I have had my tiller mounted on a 308-8 for a few years now. It has plenty of power for the job and it's great on gas. When breaking new ground with it I just set it shallow for the first pass, then go back over it again with the tiller set deeper. I have tire chains on it, they're almost a necessity with turf tires, the tiller can push the tractor. Share this post Link to post Share on other sites
Kelly 1,033 #4 Posted February 15, 2011 I've only used my tiller on my C-121 12hp, and I had more power than needed, but I will tell you these tillers don't do a very good job, on new ground, they don't have down pressure, so they bounce around a bit, if you soil is soft you should be fine, if not, do it after a rain, or water the area, not a mud puddle just wet to make it easier to till, your 310 should do fine. Share this post Link to post Share on other sites
farmer 1,078 #5 Posted February 15, 2011 I would say, depends on your soil type(hp for tilling) Also how often you cut your grass (Hp for mowing) weekly mowing on a level lawn should be easy.....so I would use the 10 horse for mowing (fuel saving) and the 416 for ground work JMO Share this post Link to post Share on other sites
Rollerman 290 #6 Posted February 15, 2011 Use the 310 for tilling, you'll need the 16HP for the 48" deck if you get into any tall or wet grass. 10HP is plenty for the tiller. The soil in my area is a clay mix that hardens like cement. I used my B 60 successfully with a tiller last fall to turn my garden in the fall. Never had much luck cutting tall or wet grass with a 48" deck & 10HP. Not that I let my yard go, but there are times life happens. Share this post Link to post Share on other sites
Docwheelhorse 2,740 #7 Posted February 19, 2011 Tiller on 310 is perfect.... I have been running a tiller on a B100 with a 10hp magnum transplant and it is more than enough power..... Tony Share this post Link to post Share on other sites
MaineDad 87 #8 Posted February 19, 2011 Use the moldbboard plow on the ground first to loosen up the soil, then from that point on the 310 will be plenty. Share this post Link to post Share on other sites
IthacaJeff 151 #9 Posted February 19, 2011 Gents: Terrific advice! I'll run the tiller on the 310, and I don't believe I'll need to plow with the moldboard first. The soil was tilled last summer during transformation of about 2 ac from farmland to "yard". Got about 8" of ice in the yard now. Yesterday's thaw and last night's freeze only served to harden up the pack. Makes for some wicked fast sledding. . . kids' are loving it! Jeff in Enfield NY Share this post Link to post Share on other sites
persof 14 #10 Posted February 22, 2011 I till with my 312-8 at a little above 1/2 throttle and that is fine. Francis Share this post Link to post Share on other sites
