Torino 14 #1 Posted February 14, 2011 What would be the best engines to repower this? looking for something fairly easy. Share this post Link to post Share on other sites
Kelly 1,028 #2 Posted February 14, 2011 I can't tell if it's a raider 10 or 12?? but it really does not matter, just about any kohler 10hp up with a big base pan will bolt it, a 8hp will but you will need a riser plate, even a engine with a 1" crank will work, the pulley and PTO sleeve are not to hard to find, a tucky will fit but you will need the proper riser plate, wiring will have to match the engine, and you may have to drill a hole in the tab on the belt guard, to bolt to the engine, I can't remember right now if the kohler has the high hole or not like your guard has. You know if you srub that tractor and wipe it down with a very light weight oil, it will bring the color out and make it look pretty good, I have a few I don't want to paint they are too nice, I wipe them down with WD-40. Share this post Link to post Share on other sites
