KB9LOR 4 #1 Posted February 14, 2011 I am in need of a couple bearings, now the WH # is 108483, and other places are showing 110513, these are front wheel bearings for the C125, anyone have a supplier? thanks! Share this post Link to post Share on other sites
Kelly 1,028 #2 Posted February 14, 2011 For cheap bearings I go to TSC, they have them in the specialty bins, for about $4 each, size 1 3/8" x 3/4" be sure to pump the hub full of grease, for nicer tractors or ones I keep, I buy sealed bearing from the local JD dealer, they are around $9 each, I get them to fit a 1994 LX188 I never have to grease them, and are nice quality, machined steel bearings, I know they can be had other places, but I've bought some else where and the quailty was not as good. Share this post Link to post Share on other sites
KB9LOR 4 #3 Posted February 15, 2011 For cheap bearings I go to TSC, they have them in the specialty bins, for about $4 each, size 1 3/8" x 3/4" be sure to pump the hub full of grease, for nicer tractors or ones I keep, I buy sealed bearing from the local JD dealer, they are around $9 each, I get them to fit a 1994 LX188 I never have to grease them, and are nice quality, machined steel bearings, I know they can be had other places, but I've bought some else where and the quailty was not as good. Thanks kelly, that is what I needed the size, I knew some JD's used the very same bearings, just wanted to verify that they could be used in a WH too. Share this post Link to post Share on other sites
rjr 0 #4 Posted February 18, 2011 You might try mscdirect.com. It is a mail order industrial supply house, or McMaster Carr (also mail order). They both have industrial bearings that size Share this post Link to post Share on other sites
