snow plow modification
the idea was to weld the agle iron to the bottom of the plow and bolt the cutting edge to it, the mod has been done will post pics of results tomarow. hope this helps someone!
the bottom of the plow was really ate up due to one of the previous owners putting a aluminum thin cutting edge on it and probably never replaced it, the bottom was really bad as you can party see
if you look closely where the cutting edge should be you can see a rust hole, but frankly when i had the angle iron welded on its took care of it, i might powder coat it or put bedliner on the bottom to toughen it up in the summer
Thanks to kelly, i used his theory to bend the plow some-what straight again
it plow great with that awesome cutting edge
yes the angle iron was welded on crooked :thumbs: but
rustyoldjunk
looks good Nick.thanks for posting the fix
