chevy030303 0 #1 Posted February 9, 2011 :thumbs: so my lever on the tractor will not push down and i need to now how to rebuild it or somthing Share this post Link to post Share on other sites
smoreau 658 #2 Posted February 9, 2011 :thumbs: what lever and what kind of tractor? need more info and maybe some pics. :thumbs: Share this post Link to post Share on other sites
Kelly 1,038 #3 Posted February 9, 2011 More info will get you answers. Share this post Link to post Share on other sites
chevy030303 0 #4 Posted February 9, 2011 sorry no pic but its 857 wheel horse it lifts the bladfor snow sorry i cant spell very good Share this post Link to post Share on other sites
Sparky-(Admin) 25,571 #5 Posted February 9, 2011 sorry i cant spell very good No offence meant by this, but maybe theres something in this thread that you might want to check out. http://www.wheelhorseforum.com/index.php?showtopic=25584 Mike...... Sorry to get . Share this post Link to post Share on other sites
Jim_M 179 #6 Posted February 9, 2011 If you mean that you can't push the button down on your lift lever, try pulling it back (like you're lifting the blade) then push the release button down. Share this post Link to post Share on other sites
chevy030303 0 #7 Posted February 9, 2011 its like the button is frozen in place Share this post Link to post Share on other sites
rwilson 128 #8 Posted February 9, 2011 If your tractor has sat outside its possible it is frozen. Try parking it inside a heated building for a little while. if you dont have access to the then try a propane torch or something. :thumbs: Share this post Link to post Share on other sites
Gene_S 93 #9 Posted February 9, 2011 Chevy unhook the plow from your lift handle and remove the hairpin cotter. Next remove the three bolts holding the handle to the tractor and remove it. When you flip it over you will see a spring that compresses when you push the button down. Make sure something isn't jammed up there. The best way to learn things is to just take it apart. Figure out how it works and then figure out why it don't work. Good luck... Plus chevy, I'm a very poor speller to... A lot of times I go to google and type the word in I'm trying to spell and most times the right word pops up. This will help you figure words out. Plus my wifes a school teacher... :thumbs: Share this post Link to post Share on other sites
dgjks6 8 #10 Posted February 9, 2011 I had that problem. The lever was bent. Share this post Link to post Share on other sites
sorekiwi 761 #11 Posted February 9, 2011 Last week, while plowing with a B-80, I noticed that my button seemed to be getting stiffer to push down. A closer inspection revealed that the weld where the round part of the lever meets the square part of the lever was starting to break, allowing the lever to bend a little and binding up the rod through the middle. I ended up switching levers out and putting the broken one on the "tuit" pile. Share this post Link to post Share on other sites
chevy030303 0 #12 Posted February 9, 2011 will im a big guy and i cant push it down and it does it win its hot Share this post Link to post Share on other sites
