repairman 7 #1 Posted February 7, 2011 WILL THE OIL PAN FROM A K-SERIES 14 HP ENGINE WORK ON THE 14 HP MAGNUM? I JUST BOUGHT THE MAGNUM TONIGHT AND REALIZED THERE ARE NO MOUNTING HOLES IN THE BOTTOM OF THE PAN TO ACCOMMODATE WHEEL HORSE FRAMES I HAVE A K-14 THEY LOOK THE SAME? :thumbs: Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #2 Posted February 7, 2011 You can drill & tap the holes you need in the Magnum pan. They are actually (in line with) the same two holes used to hold the pan to the block on that side of the engine, they just go the whole way down through. Share this post Link to post Share on other sites
repairman 7 #3 Posted February 7, 2011 OK ONE MORE QUESTION THIS MAGNUM ENGINE MODEL# M14DS DO YOU KNOW WHAT THE D STANDS FOR IN THE CODE I DON'T SEE A DESCRIPTION FOR THIS IN THE TP-2203-A MANUAL ENGINE CODE REF THE SERIAL OF THIS ENGINE IS 601526 ALSO NOT ABLE TO DETERMINE YR PRODUCED BY SERIAL AM I LOOKING IN THE WRONG MANUAL :thumbs: Share this post Link to post Share on other sites
dgjks6 8 #4 Posted February 7, 2011 try this link http://www.kohlerengines.com/onlinecatalog/pdf/tp_2203_a.pdf I have no idea what the D is for though. Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #5 Posted February 7, 2011 601526 is the SPEC number, not the serial number. I have no idea on the "D" suffix either. I have never seen that before and it's not in any of my books. Perhaps you're misreading it? :thumbs: Share this post Link to post Share on other sites
