KB9LOR 4 #1 Posted February 5, 2011 I was able to tear down my Lift Valve.......Here is a pic of my Hyd Lift Valve Shaft. the seals are shot, anyone know where a new set could be had, and/or the WH Part number? Share this post Link to post Share on other sites
KB9LOR 4 #2 Posted February 5, 2011 Okay does anyone know if those 2 rubber seals are "O" rings? I don't think they are. anyone have any info? Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #3 Posted February 5, 2011 They are probably square and should also have backer rings. Are there any hydraulic repair shops in your area? How about heavy equipment dealers like CAT, Case, etc.? I don't believe I have ever seen a parts breakdown of that particular valve, but I doubt that there's any seals that you can't get from a good hydraulic shop. Share this post Link to post Share on other sites
KB9LOR 4 #4 Posted February 5, 2011 They are probably square and should also have backer rings. Are there any hydraulic repair shops in your area? How about heavy equipment dealers like CAT, Case, etc.? I don't believe I have ever seen a parts breakdown of that particular valve, but I doubt that there's any seals that you can't get from a good hydraulic shop. Not square TT, even the hole the shaft fits in is round, I have a repair manual for a lift valve that uses the square seals, but it is nothing like this one. And compared to "O" rings, these rings look thicker than normal "O" rings, dunno, it has got me stumped And it has no backer rings at all. What you see in the picture is all that came out of that Lift valve, really strange. Share this post Link to post Share on other sites
can whlvr 994 #5 Posted February 6, 2011 just a question,did parts tree offer a rebuild kit that is still available,when i did my 1975c160auto it was still available from dealer,i look at parts tree because they tell right on the parts page if its available or not Share this post Link to post Share on other sites
Ole MN 11 #6 Posted February 6, 2011 I'm looking for the same seals. i think they are Buna-N-U cup seals. I'm looking at MSC for them. Share this post Link to post Share on other sites
KB9LOR 4 #7 Posted February 6, 2011 just a question,did parts tree offer a rebuild kit that is still available,when i did my 1975c160auto it was still available from dealer,i look at parts tree because they tell right on the parts page if its available or not Gonna have a look see at it...will update when I get it figured out. Share this post Link to post Share on other sites
KB9LOR 4 #8 Posted February 6, 2011 I'm looking for the same seals. i think they are Buna-N-U cup seals. I'm looking at MSC for them. Thanks for the help, will go and hunt around again for them, thanks for the name of those seals! It helps! Share this post Link to post Share on other sites
Indy w h 5 #9 Posted February 6, 2011 Brian , if you could gimme the exact sizes I might be able to help ya out Indy Share this post Link to post Share on other sites
KB9LOR 4 #10 Posted February 6, 2011 Brian , if you could gimme the exact sizes I might be able to help ya out Indy 5/16 ID x1/8 W x maybe 9/16? Mine are so wore I can't give a good figure on them. Share this post Link to post Share on other sites
Kelly 1,038 #11 Posted February 6, 2011 Stop at a repair shop like TT said I did when rebuilding my HY unit, they set me up with everything I needed, and took him about 5 min. Share this post Link to post Share on other sites
KB9LOR 4 #12 Posted February 6, 2011 Stop at a repair shop like TT said I did when rebuilding my HY unit, they set me up with everything I needed, and took him about 5 min. Yeah going to Monday, going to the place that had the seals for my old log splitter cylinder last year. Trying to get all info I can before going over there, and will buy xtra of the seals to help out someone else who may have the same problem I did. Thanks for the input kelly, it is appreciated. Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #13 Posted February 6, 2011 I rooted through everything I have and found absolutely nothing related to the service of pre-1973 valve assemblies. Everything I saw was either for the Oliver (OMCO) or Victor spool valves used after 1972. :thumbs: Share this post Link to post Share on other sites
KB9LOR 4 #14 Posted February 6, 2011 I rooted through everything I have and found absolutely nothing related to the service of pre-1973 valve assemblies. Everything I saw was either for the Oliver (OMCO) or Victor spool valves used after 1972. TT, I too have rooted everywhere to no avail... I guess this is going to benefit everyone who needs pre 1973 valve seals, I will post all info I get on the rebuild of the valve, well at least the putting back together part and the specs and source of the seals. Share this post Link to post Share on other sites
Ole MN 11 #15 Posted November 3, 2011 Did you ever find the seals for your Valve? Share this post Link to post Share on other sites
WheelHorseSteve 56 #16 Posted November 3, 2011 The kitchen store has them... I got a set for my c160 auto. Classic kitchens & more :dunno: Share this post Link to post Share on other sites
Indy w h 5 #17 Posted November 3, 2011 Did you ever find the seals for your Valve? I carry the pre '73 one piece valve seals Shoot me a PM Indy Share this post Link to post Share on other sites
