wheelhorse656 20 #1 Posted February 4, 2011 well i went to sart up my wheelhorse 656 toaday ad it started making a very loud knocking noise. and i mean it is bad not a little slite knock its load and sounds like the crank is completely loose. i just took it apart a moth ago to paint it and put new seals and rings in it and give it a gasket over hual kit. i torqued everything down to speck and it burns me it did this. This really just makes me sick. what really makes me sick is i dident even have a knock or anything after the slite overhual. well i gusse ill have to pull it and go on head ad finish rebuilding it. I really should have done that when it was all apart. But on a 15 year olds buget it really dident seem possible at the time. Well at least i have a brand new rod and i have already bought the rings so all i need is to do is just buy the new piston and pin and clips which shoudent cost to much. hopefully:praying:. well i gusse ill catch you later Bye Jordan P.S. i feel like shooting my self for selling that pisto i have for this tractor. :hide: Share this post Link to post Share on other sites
Sparky-(Admin) 25,562 #2 Posted February 4, 2011 Is this your only tractor? Hopefully you have a "backup" machine. Good luck with the rebuild and I hope its not as major as you think. Mike......... Share this post Link to post Share on other sites
rmaynard 17,219 #3 Posted February 4, 2011 Sorry about your problems there. The only way to find out what you need it to take it apart. Once you know what you need, we have some members that can get you parts at cost. That's one way that you will be able to save a little money. Good luck. Share this post Link to post Share on other sites
wheelhorse656 20 #4 Posted February 4, 2011 Is this your only tractor? Hopefully you have a "backup" machine. Good luck with the rebuild and I hope its not as major as you think. Mike......... yes this is my only tractor . But i am looking for another one! :thumbs: Share this post Link to post Share on other sites
corn53 4 #5 Posted February 4, 2011 Good luck with the rebuild and also with u'r hunting!!! :banghead: Share this post Link to post Share on other sites
VinsRJ 723 #6 Posted February 4, 2011 Sorry to hear about the issue. From now on...... if it aint-broke, don't fix it. Tear it down and let us know what may have failed. Share this post Link to post Share on other sites
Torino 15 #7 Posted February 4, 2011 Your not alone. I had that happen to my JD 216. It always ran good did not burn oil or smoke. My cleanest and best looking tractor. Went out to crank it and WHAM, WHAM WHAM. Have not had time to check it out. Share this post Link to post Share on other sites
wheelhorse656 20 #8 Posted February 4, 2011 Your not alone. I had that happen to my JD 216. It always ran good did not burn oil or smoke. My cleanest and best looking tractor. Went out to crank it and WHAM, WHAM WHAM. Have not had time to check it out. mine sounds just as bad ifg not worse. . i have checked all things it could be that do not involve tearing the thing apart. looks like im out of luck. oh well. Share this post Link to post Share on other sites
Torino 15 #9 Posted February 5, 2011 I have checked all things it could be that do not involve tearing the thing apart. What did you check? Maybe I should do the same. Did a compression check it was 150. Share this post Link to post Share on other sites
wheelhorse656 20 #10 Posted February 5, 2011 i checked the valve gap wich if it is to wide can cuase knocking. i alos checked the flywheel torque and if you have magnents you might want to check thier tighness as well. i also checked to see if the starter was tightend up so it was not jumping all over the place possibly cuaseing a knocking noise. then finally i checked the pully on the pto shaft to see if it was loose and banging up agianst the engine block. to bad non of these simple fixes were the cuase of my problems . hope this helps you! talk to you later Jordan Share this post Link to post Share on other sites
KB9LOR 4 #11 Posted February 5, 2011 Jordan sent you a PM..... and be SURE to use locktight on all bolts on the internal parts, you may have had a bolt loosen on the crank. Share this post Link to post Share on other sites
clintonnut 127 #12 Posted February 5, 2011 I doubt you need to replace the rings and piston. I have had the bolts forthe connecting rod come loose. It happens really quick. Charlie Share this post Link to post Share on other sites
gdhile 0 #13 Posted February 6, 2011 I worked on a wheel horse for a guy and it was doing the same i checked for carbon buildup on the head everything i could think of but i never checked the flywheel the nut came off it was a lucky and quick fix good luck Share this post Link to post Share on other sites
wheelhorse656 20 #14 Posted February 7, 2011 im gunna Start tearing her apart tomorrow and see what i can find out. ill post a video of her geting taken apart! Share this post Link to post Share on other sites
wheelhorse656 20 #15 Posted February 10, 2011 took it apart no damage!!!! the crank came loos a little bit and the timeing was off a tooth. i put on my thread lock and torqued them to speck! just need to pick up a gasket to seal the block back and i am good to go! i am just gald it did not do any major damage or anything un repairable. ill post a video of her on fire up! Bye Jordan :thumbs: Share this post Link to post Share on other sites
corn53 4 #16 Posted February 10, 2011 Cant wait to hear it run!!! Gald it wasn`t a large problem. Good luck :thumbs: Share this post Link to post Share on other sites
wheelhorse656 20 #17 Posted February 13, 2011 well i got it back together and it runs no Knock! but i do have a click coming from my valves wich will be replaced in the spring. ill get the video poseted soon! :thumbs: Share this post Link to post Share on other sites
